Canadian Forum Canadian users, post event and club info here.
Got another question
Old Apr 29, 2010 | 12:46 PM
Double_J's Avatar
Could you have your car dump boost based on fuel pressure? So if I got a digital FP gauge, and my pressure dropped I imagine it would show a different voltage. Is it possible to have it then dump boost?
My thought is if my pressure dropped I must be lean, and there for heading for trouble. If this was possible it could react quicker than I could respond to the gauge.
I know you can not do it based on AFR because you are leaner at idle/cruise compared to WOT.
Any thoughts?
Old May 3, 2010 | 07:25 PM
Andrew777's Avatar
Rotating
Your wastegate will open, "dump" exhaust flow when a target boost level is hit (whatever you have that set at) Your fuel pressure has no control of your boost levels.
Old May 3, 2010 | 07:51 PM
Double_J's Avatar
I know it normally doesn't but what I was hoping for is.....
Let's say you had a digital FP gauge, and at an unsafe reading the voltage was 2.5 ( for argument sakes ). Could you have it so that it triggered a solenoid or something else to dump boost there by saving your engine.
Very similar to how AI kits have fail safes I suppose.
Old May 3, 2010 | 08:03 PM
rd_turbo's Avatar
ERTW
Quite possible (with time and money) and a pretty good idea, Double_J. It would take some finagling, but it would be an interesting project. You need to find an electronics nerd who's into programming and creating controller boards (a few of them out there who are into building robots and such) and you might even consider making a smarter system which would take a signal from your wideband to trigger your wastegate solenoid.
Old May 3, 2010 | 08:24 PM
Double_J's Avatar
Well thanks but I was hoping it would be kinda easy. Guess that one is out the window. I will let you have that one along with the race air we talked a bout last year lol.
I had asked at one point a bout the wideband but was told that wouldn't work because you are leaner at idle, and cruise speeds. Since that idea didn't work I was trying to figure out another way that would possibly signal a lean condition.
This could also be useful for track goers too. When they make hard turns, and the fuel can run away from the pump ( yes I know they make things to help that problem :P ) but another fail safe wouldn't hurt.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
