Vacuum advance question. I do this right?
Old Apr 28, 2010 | 11:46 PM
JoeNoble's Avatar
Almost not rotarded
Old Apr 29, 2010 | 04:39 PM
purple82's Avatar
Absolute Power is Awesome
Yes.
Old Apr 29, 2010 | 05:27 PM
Kentetsu's Avatar
Try it there, and then try it on the port farthest forward. I believe the port you are using is manifold vacuum, whereas the port farthest forward is ported vacuum.
Since you don't have the rat's nest, you don't want to use manifold vacuum. Because, that would mean that it would advance the timing at idle, then retard it as soon as you press the accellerator. That would result in reduced performance.
Ported vacuum would leave the timing alone at idle, then advance it as you begin to accelerate, resulting in increased power and torque.
You can try it both ways to see what you think works best, just remember that you'll have to check/adjust the timing when changing between the two.
When you have the rat's nest installed, I believe there is a solenoid or switch that controls it to keep it from degrading performance. But without it, you should consider ported.
Make sense?
Old Apr 29, 2010 | 07:48 PM
Sgt Fox's Avatar
Stigulus Moderatorai
For stock operation on the 12A, two vacuum solenoids control the vacuum, as well as the throttle position sensor. This allows the manifold vacuum to be converted into pseudo port vacuum. The operation is as follows:
At idle, there is no vacuum present.
At 1000-1200 RPM, the leading vacuum solenoid opens applying leading vacuum advance.
At 2900-3100 RPM, the trailing vacuum solenoid opens applying trailing vacuum advance.
If throttle is released past 4000 RPM, both trailing and leading vacuum advance is cut.
Main thing is to have either port vacuum as Kentetsu said or use the stock solenoids with the TPS to convert the manifold vacuum.
Old Apr 29, 2010 | 10:32 PM
blackdeath647's Avatar
weak minds wear the crown
kent. your reasoning makes lots of sense, but i don't know what you mean by the "port farthest forward"? can you clarify?
also, i've always read on here to have it hooked to the second nipple from the left, from driver's side perspective (as Joe currently has it). unfortunately i let my girlfriend borrow my car so i don't have it with me to go check if there is vacuum at idle or not.
Old Apr 30, 2010 | 08:12 AM
purple82's Avatar
Make sense?
Thanks for the correction. There should be no vacuum at idle.
Old Apr 30, 2010 | 08:24 AM
challer2000's Avatar
Ask me about my wankel
I used the 2nd port too.
Kentetsu does it make that much of a diffrence? I'll have to try it.
JoeNoble did you notice a large decrees in MPG? When I did mine I lost 5MPG not that it matters but was just curious. I’m also running a RB collected system.
Old Apr 30, 2010 | 08:29 AM
JoeNoble's Avatar
Almost not rotarded
Challer, I didn't notice a change in mpg.
I'm starting to think there should be somethin about this in the archives.
Old Apr 30, 2010 | 09:02 AM
elmer fudd's Avatar
agreed, as im new and if this thread haddent been started i would have used the second port and assumed it was right, as every thread in the diys has it on the second port.
also there are alot of pictures missing in there.
Old Apr 30, 2010 | 09:03 AM
Stevan's Avatar
In Carl, and Pratch's Rats nest removal tutorial, it's connected to the 2nd nipple. Probably because that's where it goes stock, and they didn't have time to experiment with different vac sources for everything. I tried it on the "port farthest forward"= the nipple to the left of the the one used in Joe's photo, AKA #1, and liked the results.
Old Apr 30, 2010 | 12:29 PM
Kentetsu's Avatar
The biggest difference I felt (using the nipple at the base of the carb, closest to the front of the car) was an increase in torque in the low to mid-range operation. Made the car very peppy.
Old Apr 30, 2010 | 01:20 PM
elmer fudd's Avatar
Im a noob so don't shoot me, but has any one experimented with using both vac sources and hooking them up so one goes to leading and the other to trailing. or do they need to share a vac source? this way one would be activated at idle and the other would not, or visa versa.
Old Apr 30, 2010 | 01:38 PM
purple82's Avatar
This is the difference you felt between the two nipples? I wouldn't expect much difference at all in the way the car runs, just some idle smoothness differences since the vacuum signal should be the same once the throttle is cracked open.
Old Apr 30, 2010 | 01:41 PM
arghx's Avatar
rotorhead
Why don't you just hook the stock solenoids back up? It's clearly the best design.
Old Apr 30, 2010 | 01:55 PM
elmer fudd's Avatar
wheres the fun in that? lol
Old Apr 30, 2010 | 04:00 PM
Sgt Fox's Avatar
You can make it look quite nice:
Throttle position sensor on Weber 36DCD's
Two vacuum solenoids:
The whole package:
Old Apr 30, 2010 | 08:29 PM
Sgt Fox, I love seeing your enginebay!
Kentetsu, I just switched from the secound nipple to the first and you can feel the diffrence!
Old Apr 30, 2010 | 09:52 PM
senator's Avatar
Where is the source of vacuum on the first nipple? Im having trouble with my advance as well. I only get advance without vacuum to the dizzy, this seems backwards to me. It should be adv. with vacuum right?
When at idle if I apply vacuum with a pump it goes retarded, wtf?
Old May 1, 2010 | 11:43 AM
Kentetsu's Avatar
No, the vacuum signals are reversed between the two setups.
(without rat's nest):
Manifold: press accelerator and you start losing vacuum, which results in less advance just when you could really use it.
Ported: press accelerator and you begin advancing ignition, which results in increased torque.
Keep in mind that the differences will mainly be felt at lower rpms, and at partial throttle. It makes for a whole different driving experience around town, or in traffic. The difference is definitely noticeable.
Kentetsu's Avatar
Thank you for that! First good laugh of the day!
Old May 4, 2010 | 04:54 PM
purple82's Avatar
Not that I want to get into this again, but you really do want manifold vacuum for vacuum advance.
http://www.corvetteactioncenter.com/...m-advance.html
Old May 4, 2010 | 05:04 PM
j9fd3s's Avatar
Community Builder
i agree!
Old May 4, 2010 | 08:34 PM
Kentetsu's Avatar
Okay, because Corvettes use manifold vacuum, probably along with the same type of control that the stock 7s use, that makes it better eh? Fine, you win.
(Shakes head, turns off computer, then throws it out the window)
Old May 4, 2010 | 08:51 PM
purple82's Avatar
Corvette, Moped, lawn mower, airplane, Rx-7, combustion doesn't care much.
Old May 4, 2010 | 09:03 PM
either way, i felt some vacuum at idle from that nipple (the one furthest forward) and it stayed constant even under load.
I did feel a bit more torque, but it made my idle a bit lumpy, which i guess would be fixed once i get a timing lamp to set the trailing right where it needs to be, since i don't have one, i can only set the leading by aligning the marks on the dizzy.
