Canadian Forum Canadian users, post event and club info here.
ignition issue help pls!!!!!!!!!
Old Apr 21, 2010 | 05:41 PM
anees's Avatar
amemiya7
so the car was sitting in my basement for almost a month...
last nite i came from work and decided to fire it up but than realized that the battery was dead... so i tried charging the battery with the help pf portable charger.. the battery was fully charged after 4hours...... and i tried firing it again
and here is the problem
1. when i put the key in the car and turn it to ACC/ON...all the lights come up except the dashboard lights ..... my boost gauge/oil/temp/ cd/ radio everything works but no light on dashboard like battery/ seatbelts e.t.c
2. when i turn they key.. the car still makes the starting sound but doesnt start
3. i am guessing i blew up a fuse while charging up the battery
pls if any knows the fuse and where to look for it
or if it is something else
pls help me out guys
thanx
Old Apr 21, 2010 | 06:01 PM
JDK's Avatar
JDK
Don't think you blew a fuse, double check both battery conections....make sure they are clean and tight.
Old Apr 21, 2010 | 06:32 PM
anees's Avatar
amemiya7
i did it .. still the dash has no lights!!! and so does the car it wouldnt start.. jus makes the sound
Old Apr 22, 2010 | 12:10 PM
anees's Avatar
amemiya7
does any1 knows where is the ignition fuse or a fuse which is related to ignition
and where it could be found?
i just wana make sure that i didnt blow it up
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
