Tockico HTS in a 1st gen?!
Old Apr 21, 2010 | 03:01 PM
Ryan_13b's Avatar
From the looks of it the suspension on ae86 and a sa22c kinda look similar? are they? ive looked around and found no info. . . what are the stock specs on the front and rear shock sizes on the gslse?
any info helps!
Thanks,
Ryan
Old Apr 21, 2010 | 07:19 PM
j9fd3s's Avatar
Community Builder
i looked into doing AGX's, um compared to the AE86, the FB is way shorter, but the same diameter.
or we use REAR MR2 shocks as an upgrade
i did post all the infoz i found
i think they use this shock combo in japan, but its hard to tell
the rear is simpler, so all my research is for the front
Old Apr 21, 2010 | 08:42 PM
Ryan_13b's Avatar
So for the front insert shocks it will be too short if i bought the hts shock inserts ?
Old Apr 22, 2010 | 02:36 AM
woodonastick's Avatar
my fb is older than me
if they make it for the aw11 mr2's then you should be good. forgot exactly what year mr2. i am currently running mr2 rear in the front of my gsl. actually for sale at the moment. lol
Old Apr 22, 2010 | 12:52 PM
j9fd3s's Avatar
Community Builder
the AE86 people love to cut down the strut tube to make it a shorter strut, right? well the FB strut tube is already a bunch shorter than the AE86 tubes, even after you cut em
but the FB struts are the same length (or close enough) to the 84-88-89 mr2, the early one.
so if they have HTS's for the REAR of the early mr2, then you're good.
and the Rx7 uses the same length tube from 81-85. the 79-80's are longer by an inch or two
Old May 27, 2010 | 02:01 PM
Ryan_13b's Avatar
I found some useful size info
http://www.toymods.org.au/forums/showthread.php?t=299
so then i could run hts for a mr2 in the rear aswell?
Old May 27, 2010 | 02:28 PM
Hyper4mance2k's Avatar
The Shadetree Project
No, you use the Mr2 rear struts for the Rx7's front struts. The Rx7's rear shocks are a whole different animal. The rear Rx7 shocks are nothing like ones on the Mr2, they are similar to what is on the AE86. I have heard of Hachi Roku guys running a competition Camero rear shock as it's designed for a heavy car with high spring rates. I'm not sure what year but i'm guessing the Mk2 or Mk3 Camero.
and besides I've heard the HTS is actually softer than the illumina, so wouldn't we be working backwards here?
Old May 27, 2010 | 02:32 PM
Ryan_13b's Avatar
yea i heard of that aswell. i believe its the iROC-Z camaro
Old May 27, 2010 | 02:43 PM
j9fd3s's Avatar
Community Builder
just to be clear the REAR aw11 mr2 strut insert fits the FRONT of the 81-85 rx7
Old May 27, 2010 | 03:56 PM
Rotarx7's Avatar
hoycee$$$$$
yes
Old May 27, 2010 | 04:19 PM
j9fd3s's Avatar
Community Builder
yeah i dunno much about the HTS's but why when we actually have a couple good options that are made for our cars, like the illumina.
Old May 27, 2010 | 04:41 PM
Ryan_13b's Avatar
idk ive had a suspension set up in my corolla with hts and ground control and i really liked it. i want something similar to that. are illumina's any good? i have a set new in the box sitting in my shop. i didnt think they were anygood for the hardcore stuff haha jk
whats your feed back on them?
Old May 27, 2010 | 05:11 PM
j9fd3s's Avatar
Community Builder
sam just posted shock dyno's, they are actually a really good match for the springs we run in the rx7's...
Old May 27, 2010 | 10:33 PM
Illuminas are awesome. I run the Mr2 rear ones in the front of my FB on 5 and in the rear I have KYB gas-a-justs(NLA) 300/200 on springs and my car handles amazing. it does well enough to finish 2009 2nd in points in Street Prepared in BSCC...
Old May 28, 2010 | 12:03 PM
Kentetsu's Avatar
I run the MR2 Illuminas on the front, with Bilsteins on the rear. Very happy with the Illuminas.
Old May 29, 2010 | 07:37 PM
Ryan_13b's Avatar
thanks for the feed back guys!
demetlaw
Oct 2, 2015 06:22 PM
