Wheels
Old Apr 20, 2010 | 07:22 AM
Leading Rotarian's Avatar
Wheels
Were 14 inch wheels ever available on non GSL FB RX-7s?
Old Apr 20, 2010 | 08:08 AM
rxtasy3's Avatar
as far as i know they all came stock with 13" except for the gslse that were 14". maybe in the aftermarket owners got 14" and put on them.
Old Apr 20, 2010 | 08:20 AM
Keeble's Avatar
the LE models had 14s as well
Old Apr 20, 2010 | 11:04 AM
Super82's Avatar
Zoom Zoom
1983 LE's had 14" mesh wheels. Heres a pic of mine.
Old Apr 20, 2010 | 11:09 AM
Were any 14s made by Mazda in 4x110?
Old Apr 20, 2010 | 12:01 PM
rotarydude's Avatar
Back in the saddle again
the LE wheels are offically Mazda rims although they were manufactured by BBS. Mazda did make a 4X110 steel rim that was OEM on the 1970-2 R100 this is an extemely rare rim and is also very narrow. These are the only STOCK 14 in 4 X 110 rims that I know of
Old Apr 20, 2010 | 12:31 PM
Sgt Fox's Avatar
Stigulus Moderatorai
As stated above, the only 14" 4x110mm wheel made or licensed by Mazda for the Rx-7 was the limited edition wheel.
Old Apr 20, 2010 | 01:19 PM
That would be ok. The rule for stock is that I can use an aftermarket wheel so long as it is the same diameter as ANY one availble for my car from the factor with an offset of +/- 5mm from stock. If I knew the specs on the rare limited edition wheel, I could have diamon make a similar set up and be legal for stock.
Thx
Old Apr 20, 2010 | 02:16 PM
Also, since the 14 inch GSL SE wheel was available, I could probably use that profile. Using the same bolt pattern is not required.
Old Apr 20, 2010 | 10:37 PM
Super82's Avatar
Zoom Zoom
If I knew the offset I'd help ya out, but I don't believe mine said anywhere on them. They are 14x5.5, and just going off the top of my head they seem to be the same offset as stock, but I really can't say for sure.
FB_Frank85
Sep 6, 2015 11:29 AM
