Canadian Forum Canadian users, post event and club info here.
please explain ignition, searched for hors
Old Apr 17, 2010 | 06:45 PM
I understand how timing works for the most part.
the fsm for 3rd gen says
trailing 20 degrees atdc (-20btdc)
leading 5 degees atdc (-5btdc)
i know atdc means after top dead center
i know btdc means before top dead center
i know btdc is advances the timing and atdc is retarding the timing
i know theres the 15 degree split based on eccentric shaft degrees.
does the fsm mean the leading timing can go from 5 degrees btdc to 5 degrees to atdc and same for trailing?
what is the negative sign in the brackets for? this is driving me nuts! please explain.
how can a spark plug fire 5 degrees atdc? i thought it was always btdc
does the (-5btdc) simply mean it fires 5 degrees btdc? then whats the negative sign for? just doesnt make sense.
when people tune the leading map on a power fc, there ususally at 13-15 degrees by 15psi under full load. and thats btdc. so when is the atdc ever used? is it just for idle?
Old Apr 17, 2010 | 10:01 PM
Howi's Avatar
Like you said, most people use BTDC, or ignition advance. So I guess what the FSM is trying to say is:
trailing 20 degrees after top dead center (in other words, negative 20 degrees before top dead center)
leading 5 degrees after top dead center (in other words, negative 5 degrees before top dead center)
Howi
Old Apr 17, 2010 | 10:50 PM
awesome Howi i did alot more reading after i posted this... just trying to gain the concept of it.. i think i got it, thanks alot dude...
NEWGENRX7
Jun 26, 2019 12:20 AM
ncds_fc
19
Sep 15, 2015 12:03 AM
04G35S
Sep 9, 2015 07:05 AM
