Introduce yourself New members post about yourself here...
82 rx7
Old Apr 17, 2010 | 01:41 AM
82baby's Avatar
82 rx7
hey guys my name is mark i live in salem and i was wondering if anyone new some quick upgrades for a 12a
Old Apr 17, 2010 | 03:08 AM
mar3's Avatar
Administrator
An electric fan and then a good exhaust system are good, relatively cheap first timer mods that will reward your efforts quite well.
Welcome aboard, Mark! The more 1stgen guys joining the board, the better, sez I!
Mario III
Old Apr 18, 2010 | 07:46 PM
hoofhearted's Avatar
Photon co-inventor
Factory 4barrell came with only two operable.
Mark,
There is a lever with a spring and a T-top on the stock carb that, when delivered new from the factory, was set so only two of the four barrels worked. The dealership used to charge $85 to modify it so that all four barrels worked. A needle nosed plier and 10 seconds could save you $85 if you knew "the secret". Grab the top of the lever/plunger, near the T. Pull up; hook the "T" on to the arm a few inches above it. The secondaries are now operable.
Bob
Th0m4s
Feb 26, 2019 02:04 AM
