Remove throttle cable
Old Apr 16, 2010 | 05:48 PM
jonathan_ed3's Avatar
How does the throttle cable come out of the firewall? It looks like there's some sort of clip on the interior side of the firewall but I don't understand how it releases. I don't want to break it.
Old Apr 16, 2010 | 06:50 PM
Siraniko's Avatar
RX for fun
cable casing snaps into the firewall while the cable itself snaps to the pedal
Old Apr 16, 2010 | 07:17 PM
So i can just push it outward from underneath the dashboard?
Thanks!
Old Apr 17, 2010 | 06:47 PM
Triangle Powered's Avatar
yeah, i've done this like 3 times haha(had my cable snap on me. The cable does clip to the peddal but iam not sure if it will just slide out of the firewall bracket and the bracket is a pita to get off.
Old Apr 18, 2010 | 04:52 AM
mazdaverx713b's Avatar
Have RX-7, will restore
its not as easy as it sounds..there are four small clips on the back of the firewall mount that must be depressed together from inside of the car...after those are depressed, the mount will be free from the firewall. the cable attatches to the accelerator pedal bracket via a plastic grommet. depress the two tabs and move outward.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
risingsunroof82
Sep 7, 2015 01:11 PM
