Help Analyse Boost Pattern
Old Jun 20, 2002 | 05:29 AM
chachidu's Avatar
First turbo (8.5 to 10 Psi)
Transition (5.5 to 7 Psi)
Second Turbo (8-9 psi always) with boost gauge needle shaking.
I think the first turbo is fine. it just reacts differently depending on how the acceleration starts...i.e. sudden as opposed to gradual. Gradually it gets up to 10 psi usually...randomly flooring it it gets up to like 8.5...the transition seems a bit low and obviously the second turbo is not up to par cuz it never gets to 10psi. What could be causes?
Old Jun 20, 2002 | 07:01 AM
mmaragos's Avatar
Check the basics too.
Are you still running a precat? If yes, depending on age and usage, it may be getting plugged.
Are you still running a cat? If yes, depending on age and usage, it may be getting plugged.
With the boost gauge needle shaking, that could indicate a boost leak. Check the coupler between the y-pipe and pipe to the intercooler. Check all of the intercooler piping to make sure that you do not have any leaks.
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
Ian_D
Oct 14, 2015 12:31 PM
