Plug up air box
Old Apr 14, 2010 | 04:27 PM
009's Avatar
009
Plug up air box
Hello all rx7 masters, I just remove little flapper and tape up the 2 holes. My question is can I plug up all the holes on the bottom of the air box? And what can I use to plug the 2 vacuum line on the passenger side of the air box that on the engine itself. The rest i use tape and plug. Thanks for any inputs.....
Old Apr 14, 2010 | 06:43 PM
1stGenJake's Avatar
need hood
I did. I took the whole thing off, cut the tubes with a hack saw, filled them with jb weld on the top and tape on the bottom. When it cured I took the tape off. I haven't had any problems yet, but just wait... If I was wrong to do that, someone will be here to verbally abuse me for it. (and hopefully with good reason)
-Jake
Also if your talking about the vacuum line on the intake manifold. JB weld and a screw to fit.
Old Apr 14, 2010 | 07:36 PM
009's Avatar
009
I tape off all the holes on the air box. Then plug all the line back in. What if 1 of these foil tape get into an engine, will that cause any damage?
Old Apr 14, 2010 | 07:47 PM
1stGenJake's Avatar
need hood
Possibly? The vacuum plugs alone should be enough to hold if they are the right size. I took the air box off the car and let the JB weld cure overnight, then remove the tape, which is just keeping the JB weld in place. But like I said before, wait for a good response, not just me being bored and posting what I have done.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
