purge control lines?
Old Jun 19, 2002 | 10:37 PM
PESZKO's Avatar
just about done with vac. hose job. but can't tell from vac. hose diagram if the vac. hose form the catch tank conects to the top or bottom nipple of the purge control solenoid valve. that leaves the other line of the purge control to the manifold. anyone have a good photo or diagram.
Old Jun 20, 2002 | 03:03 AM
GsrSol's Avatar
Z06 powered FD
What diagram are you going by? Have you checked the Rob Robinette diagram?
Old Jun 20, 2002 | 02:19 PM
PESZKO's Avatar
yes i used thr rob robinette diagram, but it was not clear enough as to what was the top or bottom line.
and for the catch tank to the top nipple do you meen the one that furthest extends out?? if anyone has a photo of this line conect please direct me to it. also if the lines are backwards will there be any adverse effects?? thanks for helping out!!!
