installed weber no spark
Old Apr 11, 2010 | 02:32 AM
ronrx7s2's Avatar
Unhappy installed weber no spark
hi everyone i need help. ihave a 82 rx7 s2 and i installed a weber carb to stock 12a, i just unplugged all the electrical leads to nikki carb removed nikki and put on webber carb engine will not fire ihave spark and power to dizzy but no spark to plugs can anyone help plse
thks ron
Old Apr 11, 2010 | 12:00 PM
RXnos1200's Avatar
1200 gone......but......
you posted "ihave spark and power to dizzy but no spark to plugs "
where do you have spark at?
cap and rotor on right?
igniters working?
12v's to the coils when ignition on?
Old Apr 13, 2010 | 03:09 AM
ronrx7s2's Avatar
yes thats right i have power to and from coils to dizzy i have power to igniters but have no spark from dizzy to plugs. Iam checking igniters but cant understand why they should not be working as car was running fine until niki carb disconnnected. and if they have faulted what caused this. im at a lost because everyone i spoken to and posted threads have said that all of theirs just fired up and ran with out problems
thks ron
Old Apr 13, 2010 | 07:51 AM
RXnos1200's Avatar
Changing the carb should have nothing to do with your ignition system......that I know of...
just have to check out your ignition system.
gap in distributor for pickups, cap and rotor, wires, igniters, plugs......check volts to the coils when cranking over the engine.......
FC_DREAMS
Aug 30, 2015 09:12 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
