distributor timing
Old Apr 8, 2010 | 03:59 PM
tony94s4's Avatar
Corn Fed FD
distributor timing
need help with 85 gslse 12a engine
its a drag car only with e85 fuel with holley 650
how much timing the most I should run
the puley is not stock so not sure how much timing I have
if I turn the distributor all the way to end advanced how much timing is
and all the way retarded how much timing it is roughly
thnx in advance
tony
Old Apr 8, 2010 | 07:15 PM
installer67's Avatar
Dreamin of drivin my 7!
I can't tell you what timing to run, it depends on your engine mods, porting, etc. I can tell ya that the timing issues are a fairly common question and can be found by searching "timing" in the first gen. section.
You also might get a better answer by asking in the "racing" section, where they may be more familiar with that type of setup.
Old Apr 9, 2010 | 10:13 AM
DivinDriver's Avatar
1st-Class Engine Janitor
You'll need to get your pulley properly marked for #1 TDC & degrees from there before you can do much else, so I'd research "finding TDC" while you're at it.
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
Joe428
16
Aug 19, 2015 06:24 PM
