Drifting Discuss Drifting and drifting techniques here.
Pinion snubber preload.
Old Apr 7, 2010 | 02:17 PM
NoPistons!'s Avatar
Tango Down
Anyone doing this with good results. Just curious of what i'll expect. I predict not shearing my diff mount. I dont have any suspension bushings done in the rear end but dtss. Just the snubber. I think it's all i need really.
Old Apr 8, 2010 | 05:29 PM
lonetlan's Avatar
Too Many Questions
The way I figured pre-load is to space the snubber with one big washer on top(spread load), and two on the bottom. My snubber is makeing contact with the diff when my car is on the ground.
My results on the streets is that when I initiate, my rear end isn't that bumpy. My tires stay flat. I'm N/A, so I really like it. I haven't changed my rear bushings yet either.
Old Apr 9, 2010 | 02:59 AM
NoPistons!'s Avatar
Tango Down
Thanks bro! Just the answer i was looking for. I mean, i've seen a couple of people suggest it and how to install it but i never recalled seeing if people left space or let it rest on the diff. Never saw any reasoning other than "it keeps you from breaking your front diff mount".
Old Apr 11, 2010 | 07:32 AM
danegerous's Avatar
it go down in the dm
You can flip your subframe mounts and they will act the same as solid bushings too if you didn't know. I'm talking about the round guys towards the front of the car.
Old Apr 11, 2010 | 11:49 PM
NoPistons!'s Avatar
Tango Down
That's too much work. I'd just rather fill the bastards in with window weld but thanks for the tip. Knowing my luck i'd rip them all to hell trying to get them out of the subframe. I seem to break everything i touch.
MILOS7
Oct 1, 2015 08:00 PM
Ernstudet22
Sep 14, 2015 09:19 PM
