Sponsored by: CARiD
feeding a 044 with a walbro 255
Old Apr 5, 2010 | 09:47 PM
kevyn_rx7's Avatar
I'm charming
I'm going to buy a 044 this week. According to jayracing.com it is recommended to run the 044 out of tank and feed it with a smaller in tank pump. I've been browsing through some other random forums for more info. and I found a good bit on an SRT forum supporting this setup.
I currently have a 255 in tank. Has anyone done this? How is it wired?
Thanks!
Old Apr 5, 2010 | 10:35 PM
a_reyes1014's Avatar
I actually have mine wired up from the same relay and same ground.
Old Apr 5, 2010 | 10:44 PM
kevyn_rx7's Avatar
I'm charming
are you getting your power source directly from the battery?
Old Apr 6, 2010 | 05:02 PM
2a+RoN's Avatar
feeding an 044 with a 255 is a proven setup. T1 has done countless fuel systems with this pump combo and its been found to be solid, even at higher pressures (some running 100psi base).
cto_2
19
May 8, 2018 08:15 AM
James Knox
Oct 22, 2015 05:08 PM
eplusz
15
Oct 7, 2015 04:04 PM
