strange problem, engine turns but wont crank
Old Apr 3, 2010 | 06:19 PM
Laz93RX7's Avatar
All Hail the Magic Conch!
Question strange problem, engine turns but wont crank
have an 86' car has never had this problem until a few days ago. if I give press the gas a couple times it starts and has 13-14v steady and stays on runs with no problem until I turn it off then it wont turn on. Also if I jump start it it will turn on aswell. has anyone experiened this? new engine 2k miles 18-19vac, plugs are getting spark. fuses and relays are good too. this really has me scratching my head.
Old Apr 3, 2010 | 06:41 PM
farberio's Avatar
NASA-MW ST4
So....you are saying your starter doesn't work?
Old Apr 3, 2010 | 07:36 PM
Laz93RX7's Avatar
starter is new.
Old Apr 5, 2010 | 06:41 AM
Laz93RX7's Avatar
anyone experience this.
Old Apr 5, 2010 | 06:47 AM
Go48's Avatar
Clarify your problem. "...engine turns but wont crank" doesn't compute. Does that mean the engine turns over with the starter (same as crank) but does not start? Or does the starter not even turn the engine over (crank)? Two different problems requiring different troubleshooting procedures.
Old Apr 5, 2010 | 12:45 PM
Laz93RX7's Avatar
car turns over but does not start. now its gotten worse when I get it to run now when I do get it to start and give it gas it dies. again plugs are clean/new, starter is new, battery is good.
Old Apr 5, 2010 | 01:45 PM
Go48's Avatar
Well, if the engine turns over the battery and starter are obviously OK. Sounds like it may be fuel related. When the car dies, remove a leading plug and inspect for fuel fouling. If it's wet with fuel, you are flooding the engine. That may be due to your starting procedure or to low engine compression. Check engine compression.
http://www.rotorwiki.com/index.php/Blown_Engine_Diag
If it is dry, check the fuel pump, the fuel filter and the fuel strainer on the fuel pump.
Old Apr 5, 2010 | 04:49 PM
Laz93RX7's Avatar
engine comp is good, plugs are dry. got 40psi fuel pressure
Old Apr 6, 2010 | 04:33 PM
Laz93RX7's Avatar
bump
Old Apr 6, 2010 | 05:14 PM
farberio's Avatar
NASA-MW ST4
Have you tested for spark?
When you get it to start will it idle for long periods of time?
Old Apr 6, 2010 | 06:41 PM
Laz93RX7's Avatar
there is spark. when it starts, it drives fine wont die or sputter, nothing. when you turn it off and try to start it up again, nothing.
Old Apr 6, 2010 | 08:04 PM
Laz93RX7's Avatar
dont know what else it could be?
Old Apr 6, 2010 | 08:14 PM
FuriousComet's Avatar
My rebuild had this problem... I would have to let the engine cool for a little it would crank over. Now i have more problems....
Old Apr 6, 2010 | 08:17 PM
duo2999's Avatar
Pabs
when you say nothing, do you mean the car doesnt do anything at all or it just cranks and cranks and cranks?
have you checked for codes? do you let the engine warm up to normal temp and then shut it off and then it wont start up again?
Old Apr 6, 2010 | 08:37 PM
farberio's Avatar
NASA-MW ST4
Yes or No?
Whet the engine is cold or has been sitting for a long time it starts. (yes/no)
When the engine is hot or I try to restart the car within a small amount of time from running it does not want to start. (yes/no)
Old Apr 7, 2010 | 05:29 AM
Laz93RX7's Avatar
When the engine is cold or has been sitting for a long time it starts.
if I press on the gas or jump start it, yes. no it has not been sitting for a long time just finished breaking in the motor.
yes it will start if its hot , If I jump it or give it gas. No it will not start within a small amount of time after running.
Old Apr 7, 2010 | 08:14 AM
jm93rx7's Avatar
Committee Member #3
Is the Microtech showing a red LED?
Old Apr 7, 2010 | 08:18 AM
Dltreezan's Avatar
My Bick is Digger
microtech is on his FD
Old Apr 7, 2010 | 08:22 AM
Laz93RX7's Avatar
it does have a microtech, but no blinking red led. no errors showing.
Old Apr 7, 2010 | 08:46 AM
jm93rx7's Avatar
Committee Member #3
Primary injectors cleaned and in good working order?
Old Apr 7, 2010 | 11:40 AM
cout's Avatar
On my S5 there are two hoses connected side-by-side to the intake; one goes to the air pump and I'm not sure what the other one is. Whenever I remove the intake to gain access to something underneath and I forget to reattach these hoses, I see similar behavior to what I think you are describing (engine won't start unless I give it gas, and even then it runs rough, then it dies once I stop giving it gas).
I'm not sure why this is; I always assumed it was because the pressure drop throws off the MAP sensor readings. Check your intake to make sure there aren't any leaks.
Old Apr 7, 2010 | 11:49 AM
Primos003's Avatar
I thought that if you started a rotary and didn't let it warm up all the way before turning it off, it would flood the engine. My car does this... What i do is take out the EGI fuse (I think thats what its called) and crank it over a few times, then plug it back in and it usually starts right up. It could also have something to do with the TPS, test it and set it within specs.
Also before posting a comment, read it over and make sure it makes sense...
Old Apr 7, 2010 | 04:49 PM
Laz93RX7's Avatar
injectors are new, all vacuum lines are capped or connected onto their proper location.
Old Apr 7, 2010 | 05:07 PM
farberio's Avatar
NASA-MW ST4
Check your idler screw, maybe you are too short and its closing off the TB when the pedal is not pressed. Sounds like you are having 'hot start' problems.
Old Apr 7, 2010 | 06:07 PM
SpikeDerailed's Avatar
This sh*t burns oil!
sounds to me like the hot start problem. have you checked to make sure all the coolant sensors are connected and the outputs are correct?
