T3 turbo blanket fit on HT18 compressor?
Old Apr 3, 2010 | 10:54 AM
Grip's Avatar
i destroyed my heatshield when removing my turbo, wondering if a T3 sized turbo blanket will fit my S4's HT18 compressor?
Old Apr 3, 2010 | 02:57 PM
Grip's Avatar
nobody knows if the HT18's compressor is similar in size to a T3?
Old Apr 3, 2010 | 05:26 PM
john ward's Avatar
oi oi oi
Id love to know as well. Ive been looking at the summit blankets wondering what would work.
Old Apr 4, 2010 | 09:03 AM
2slow4stock's Avatar
The waiting game......
Chea, I but I need a blanket that covers the hot side. Anyone know?
Old Apr 4, 2010 | 09:56 AM
arghx's Avatar
rotorhead
I think it's worth a shot. The T4 blankets fit a large variety of turbos, it would make sense that the T3 ones would fit something the size of an HT18S-2S. It's a pretty big hotside for a stock turbo.
Old Apr 4, 2010 | 12:33 PM
Grip's Avatar
that's what i was thinking before spending the $155
Old Apr 4, 2010 | 06:57 PM
SirCygnus's Avatar
whats going on?
just buy it dude.
Old Apr 4, 2010 | 10:20 PM
Grip's Avatar
Originally Posted by SirCygnus
just buy it dude.
Great advice....is that how you purchase **** for your car? Just buy it and hope it's right when it arrives?
Idiot.
Old Apr 5, 2010 | 04:20 AM
sharingan 19's Avatar
Rotary Revolutionary
wouldn't the utility of a turbo blanket be greatest when placed around the turbine as opposed to the compressor?
Old Apr 5, 2010 | 03:20 PM
^^ Yes, That's why I asked for the hotside. But you have gains from the compressor also IF you insulate the hotside, manifold, down pipe.
I would think the t3 blanket for the turbine housing would be kinda small don't you think? Since most of the t3/t4 turbos have a .63 - .83 a/r housing. Stock TII hot sides are 1.0 a/r. S4 and S5 have the same hotside a.r and compressor housing.
Old Jan 20, 2011 | 08:23 PM
blackedoutFC3S's Avatar
HKS obsessed
I know this is kind of an older thread but has anyone actually tried this? Same issue happened to me so just trying to figure out if it can be used or not.
Old Jan 20, 2011 | 08:48 PM
texFCturboII's Avatar
version 2.0
Yea, I tried it. It will fit, but the stock turbo is placed very close to the intake manifold; it makes it a very tight fit. I was kind of afraid that being completely wedged between the manifold and the hotside would cause the material to ignite.... any comments on that?
Old Jan 20, 2011 | 08:54 PM
HKS obsessed
Which blanket are you using?
Old Jan 20, 2011 | 09:36 PM
Hypertek's Avatar
Slowpoke
the thing was made to be in contact with the turbine why would it be a worry? Is it pinched? Or your worried that since it is soo close next to the intake manifold that it isnt surrounded by roomy air?
K-Tune's Avatar
FD Daily
keep in mind those blankets aren't designed for internally gated turbines...you would need a way to attach the wastegate actuator. the stock heat shields work best on the stock turbo. how on earth you ruined them while taking them off is beyond me...
Old Jan 20, 2011 | 09:38 PM
Hypertek's Avatar
Slowpoke
make some alteration slot for the arm.
Cut and run it through a sewing machine
would be nice if we could do the diy stainless steel pot heatsheild
edit: you could probably do that trick, just cut the pot up and bolt it to the turbine housing/chra bolts.
Old Jan 22, 2011 | 12:55 AM
unek87's Avatar
NA-BOOSTIN
^ diy all the way brotha lol
Old Jan 22, 2011 | 02:14 AM
version 2.0
Yes, exactly. It is / would be pinched between the manifold and the turbine. I don't wanna start nor fires here.
Old Jan 22, 2011 | 08:59 AM
Molotovman's Avatar
Ban Peak
Idiot.
You're a pompous *** Grip.
I hope your car catches on fire and burns to the ground.
**** you.
Old Jan 22, 2011 | 09:31 AM
Old Jan 22, 2011 | 10:02 AM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
**** you.
http://www.pissandmoan.com/
Old Feb 21, 2011 | 12:35 AM
JustJeff's Avatar
Apex Seal Treachery!!!!!!
Before I put my engine back in the car I need to replace my OEM heatshield also. I'm new to turbo blankets. And I've seen them varying prices. Is a blanket a blanket a blanket?
I'm getting some things from Prosport anyway and figured this might be a good option. It's either that or find an OEM heatshield....but those are all going to be 20yrs old and probably not much life left in them.
http://prosportgauges.com/turbo-heat...t-t3-Grey.aspx
Old Feb 21, 2011 | 12:46 AM
RotaryRocket88's Avatar
Top Down, Boost Up
If you can find some OEM heatshields that aren't rusted out, you can just clean them up. Scotchbrite and some high temp paint will have them looking new again. They're just metal, so there's really no "life" to them unless they rust.
Old Feb 21, 2011 | 12:53 AM
JustJeff's Avatar
My problem with the old one was the welded tabs that fastened the shield down were coming free. This happened before I detonated the engine and the shield was partially lying on the turbo and rattling. I got annoyed one day and cut it off.
I'll make a WTB thread and see if I can find one. But I do like the idea of putting something new on rather than worry about having to mess with an OEM shield down the road.
Old Oct 26, 2019 | 11:40 AM
mr_vaughn's Avatar
Chillin
Any recent changes over the years with this?
I need to do the same to my S5.
I got this and it is a close fit. (short about and 1" on length) and " on downpipe side.
https://thermalzero.com/product/univ...turbo-blanket/
but thinking that I can get a custom blanket made that is like this that will fit the S4/S5 turbos better
https://thermalzero.com/product/lava...blanket-short/
