6 ports??
Old Apr 2, 2010 | 07:03 PM
br4nd0n's Avatar
Need na haltech base map
6 ports??
If the 6 ports are wired open would it be more beneficial to just pull the sleeves out??
More air = more top end power??
Old Apr 2, 2010 | 08:05 PM
SoloII///M's Avatar
Captain OCD
I doubt it. The sleeves are pretty thin. But wiring them open sucks as well, so why not make things worse?
Old Apr 2, 2010 | 09:43 PM
arghx's Avatar
rotorhead
people have done both. I had the pineapple sleeves wired open for a while. I'm wouldn't go out of your way to remove them. Ideally you would just get the system working properly. In your sig it has an s5. Are your sleeves stuck or something? Put the air pump, VDI solenoid, and 6 port solenoid back on and just control them like factory. You can still eliminate most of the rest of the vacuum routing.
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
