newbie questions
Old Jun 19, 2002 | 07:35 AM
Question newbie questions
ok im new at the rx7 era...i was into VW's my whole life and got sick of the mess...so now i have an 88 turbo with 110,000 miles on it and i picked it up for a thousand dollars...couple of questions....i have an oil cooler leak and im not sure if its the lines or the cooler itself anyone know a quick cheap remidy? secondly the body of my car is in great shape...and i have the squared tail lights and i would really like the rounded ones..so A. will they fit? and B. where do i fin them?
thanks for all your help guys
jeff
Old Jun 19, 2002 | 07:42 AM
1_dollar_83_RX7's Avatar
Im pretty sure the lights bolt right on, look in the classified section on the forum and try to get those lights used, or search your local junkyard
...89-91 have the round lights
does you car run for 1000$? and does the turbo work, if so lucky you!
Old Jun 19, 2002 | 07:52 AM
yeah it runs great actually...well asfar as i can tell nothing but that oi line is wrong and yeah the turbo spools fine
Old Jun 19, 2002 | 07:54 AM
RETed's Avatar
Re: newbie questions
Replace them - it's going to bite you in the *** if it fails.&nbsp It's most likely the oil cooler lines.&nbsp This is especially true if they are original.&nbsp There are several vendors that offer replacement SS lines for a little over $100.&nbsp Corksport http://www.corksport.com/ and Mazdatrix http://www.mazdatrix.com/ offer them - bookmark these two sites; they are both very helpful for finding parts.
If you can't afford $150 pair of oil cooler lines, you should dump the car.&nbsp Many good used examples of these cars are around, but (IMO) it takes another $1000 - $2000 to get them back up to good, reliable running condition, so I hope you got the money to do this.
-Ted
Old Jun 19, 2002 | 08:00 AM
good advice
Old Jun 19, 2002 | 08:14 AM
RETed's Avatar
If you're really in a bind for money, try and track down a local hydraulic shop that will do "rebuilds" for your original lines.&nbsp I've heard of folks getting away with as cheap as $50 for this job.
-Ted
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
