Canadian Forum Canadian users, post event and club info here.
Should I remove the aux port valves?
Old Mar 28, 2010 | 02:52 PM
Ctrl's Avatar
My other car is a TVR
I've got 6 port 13b, street ported with rx8 rotational assembly and resultant compression, K&N intake, RB exhaust. I've upgraded the secondary injectors to 550cc. There are other mods to the car but none worth mentioning here as I don't think they would affect the running of the engine per se.
The car since I got it about 4 years ago has always been a fire breather, but I seriously suspect the injector upgrade is massively over-fueling the engine.
Today while maintaining the car I noticed one of my actutators is seizing up and to see what happens I wired them both fully open. In theory, from what I've been told, this extra air should kill my low end torque but increase power in the top end.
I just came back from a test drive and I'd have to say that low-end is about the same, mid-range is better, and top end seems better too... likely due to one actuator open for the first time in a long time. The car seems to spit fire less, so IOW, the gas is burning in the engine where it should be.
If the 550cc injectors are over fueling the engine, wouldn't removing the aux port valves help things all around?
Old Mar 28, 2010 | 03:44 PM
Bwek's Avatar
High Comp Booster
No it would not help the 550's are probably hurting your top end
is the motor running off the stock ecu?
to put it in to perspective even with the stock 440's the its rich up top
Old Mar 28, 2010 | 04:06 PM
Ctrl's Avatar
Yeah, stock ecu.
I'm not expert but I'm not sure top end is much of a problem... 6 to 8k RPM seems to be where the power kicks you in the seat of the pants.
With all that over-fueling, do you think I could get away with a NOS dry kit?
Old Mar 28, 2010 | 06:38 PM
Bwek's Avatar
High Comp Booster
Originally Posted by Ctrl
Yeah, stock ecu.
God no you need a proper tune and at a minimum a Wideband o2 to know where you are at
Old Mar 28, 2010 | 07:32 PM
Ctrl's Avatar
Would a wideband o2 require some 3rd party engine management? If so, can the stock ecu be remapped?
There's a base model s4 in the boneyard right now... I better go scoop up those 440's before their gone.
Old Mar 28, 2010 | 11:21 PM
Alak's Avatar
A wideband is its own little unit. Usually they come with the proper guage.
off-topic:
Hows the TVR? I havent heard from you in years.
Old Mar 29, 2010 | 07:20 PM
Ctrl's Avatar
off-topic:
Greetings Sean, it's good to see you again. I'm just about to roll out the TVR as soon as they sweep up these damned rocks off the road left over from winter.
I just did a full body-off chassis restoration... all my own work and elbow grease.
I've got a full thread with hundreds of pics on pistonheads.com, but to give a small sample of the work and attention to detail I've done, check this out:
Yeah, I own a VW as well now.
http://www.vwforum.com/forums/f34/my...its-tvr-40192/
For the FULL restoration thread with far more pics see: http://www.pistonheads.com/gassing/t...599&i=0&nmt=My nightmare... errr restoration thread.&mid=72599
Old Mar 29, 2010 | 10:50 PM
Alak's Avatar
Cool man, we'll have to check it out in the summer. Good to see you still got her.
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
