New to the FD and have some questions about my wheels and tires.
Old Mar 27, 2010 | 11:30 AM
Medpilot's Avatar
Thread Killer
First off, Hello! Just spent most of the last 11 years deep into MR2s. They are a great car, but I went too far with it and finally bailed out for something more reliable and less temperamental and got an 94' FD deal on a blown engine from a board member here. I have sold off the MR2 and 11 years of parts, so now I am going extreme with the RX7 and will probably tick some of you off by saying this, but it will be an LSX, with about $40K worth of parts on her.
Anyway, Left over from the MR2 are my custom made Forgeline rims and tires, that are brand new. I would really like to use them, but since I haven't gotten my parts list together for the suspension yet and the car is currently stock, I haven't been to the point of test fitting them. I would like your advice on what I might experience when I do.
The rims are 18x10 with 285/30/18s front and 18x12 with 345/30/18 rear. Both have 6mm offsets.
I intend to use Shine auto 20mm fenders and Petit racing rear flares.
So, how bad is the news boys?
Old Mar 27, 2010 | 11:45 AM
Scrub's Avatar
bow leggin'
The fronts will definitely not fit, especially with 285's, I have no idea about the rears.
I'm running 18x9.5 +15 with 255's front and they barely fit. My front fenders are 20mm over.
The bad news is those petit race flares are pretty horrendous.
Old Mar 27, 2010 | 01:07 PM
Medpilot's Avatar
Thread Killer
I see. I found this cool tool: http://www.rimsntires.com/rt_specs.jsp
Coupled with the sticky .xls on this forum and I cam up with that I would need to modify the fenders to extend about 1" +/- a little on the front and the rears may need 1/2" or so to be good. I need to look at the wheels, I may be able to mill off a little material from the hub too.
Why do you say "horrendous"? are you talking about fitting, or that you just don't like them? I do plan on molding them in.
Thanks for your input.
Tyson
Last edited by Medpilot; Mar 27, 2010 at 01:26 PM. Reason: Forgot to subtract the difference of the fenders.
Old Mar 29, 2010 | 12:26 AM
Miata_mx5's Avatar
Wangan Nasty
If you truly care about performance you should pick the tire compound first, then pick the size, then pick the wheel to go with that. Then build the car to fit it. 285 front and 345 rear is very overkill even for a 450 hp or something v8.
diabolical1
30
Jan 30, 2016 05:50 AM
