Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek cranking fuel map lost
Old Mar 23, 2010 | 05:05 PM
fc3schick87's Avatar
Rotary Addiction
ok i had some errors with my palm and it lead to wiping out my stock cranking fuel map. the tab that says starting. its a lil line graph that adds or removes fuel on start up..
could some one load theirs up on their palm and take a picture of theirs with their camera and post up the picture? or at least type out the different points on the map
for example. at 75 degrees the cranking fuel should be ____
a picture would be much more simple as i need to fine tune the starting any way... i just have no base line at all right now....
thanks!
-jessica
Old Mar 23, 2010 | 05:16 PM
Nick_d_TII's Avatar
Cranking fuel, this works for me, but it's pretty easy to adjust and if you flood it just hold your foot to the floor when cranking...
Old Mar 26, 2010 | 04:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Just had the same problem recently: https://www.rx7club.com/rtek-forum-168/starting-fuel-map-886098/.
From the look of Nick's graph, I'm running just about the same amount of fuel in my start map.
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
