blitz dual sbc boost controller not changing boost
Old Mar 21, 2010 | 10:35 PM
VATOCLOWN's Avatar
ok heres the issue i have an 1972 rx2 with an 1989 turbo 2 13b in it have an upgraded bosh fuel pump and an areo motive fpr costum headers and an upgaded turbo t3/t4 with a 7psi internal wategate. i installed an blitz dual sbc spec s boost contoller i had lying around. but i cant get the boost to increase at all cant get the boost to go over .51 bars witch is about 7.2-7.3 psi. im trying to get to 10 psi or even more if possible but cant get over 7 or so can some one help.
Old Mar 22, 2010 | 10:43 AM
Aaron Cake's Avatar
Engine, Not Motor
How have you plumbed the controller?
Are you using the stock ECU? If so, did you bypass the stock boost solenoid?
Old Mar 22, 2010 | 04:53 PM
VATOCLOWN's Avatar
the controller has pluming. i am using the stock ecu, is the stock boost solenoid the pressure sensor if so i removed the line and blocked it off but that didnt help
Old Mar 23, 2010 | 10:39 AM
Aaron Cake's Avatar
Engine, Not Motor
How have you plumbed the controller? Do you have a diagram?
Old May 6, 2010 | 09:57 PM
VATOCLOWN's Avatar
can someone help me out here is a video of how i have the controller hooked up
http://www.youtube.com/user/VATOCLOWN1
http://www.youtube.com/watch?v=KhyBaUehWCU
Old May 8, 2010 | 10:58 AM
Aaron Cake's Avatar
Engine, Not Motor
Everything looks correct in your video but I'm not really familiar with this specific boost controller. Does it have a setting for the type of wastegate used? Make sure that it is set to a swing valve/flapper and not a poppet type.
How many ports does the solenoid have?
Old May 8, 2010 | 01:32 PM
VATOCLOWN's Avatar
the solenoid has 3 ports one in one out and one bleeder.
the thing is i had it working in my 240 with no problems
