FB Help please
Old Mar 21, 2010 | 12:12 AM
rx7w/yaw's Avatar
Stay Into It!
Unhappy FB Help please
So before anyone jumps the gun about me not searching... I have.
On Thursday I did the atf trick and wouldn't you know it... IT WORKED!!! I was so excited when my FB started on Friday I just about cried(ok i did), but my happiness was short lived.
Well I cranked it over and at first it would only start with the throttle pegged to the floor, if I let off at all it would die and it was bogging(rpm @ 1K)??? It did this over and over as I tried different techniques to try and keep it running and to no avail, but I did find that I could keep the starter going and it was like a crutch carrying the rpms higher because as soon as I let go of the key(with the throttle wide open) it would maintain the rpms that it reached with the help of the starter(5k was the highest I took it).
Then I fouled out the plugs so I let it air out and put new ones in. With the new plugs it played a different game... now i had to pump the gas, then attempt to start it, but it would only run if I bounced my foot on the throttle about an inch up and down(maintained 1k to 1.5k rpm). I soon found I could bounce my foot at a faster pace to bring the rpms up, but I couldn't hold my foot steady or it would just die. I also couldn't bring the rpms down any way without it dieing.
My only question is what could be causing this and how would I go about fixing it?
FYI This whole time Ive been pouring gas into the carb because I havn't looked and gone through the fuel system yet. (1983 12A all stock)
This forum has been so much help and such a wonderful helping tool, and thank you for your answers in advance!
Old Mar 22, 2010 | 10:35 AM
Kentetsu's Avatar
Look at the section on "how to tune the idle". www.sterlingmetalworks.com
Sounds like you just need to set the idle and idle mixture. Good luck.
