need to use a belt sander
Old Mar 20, 2010 | 08:44 PM
jinxed4dub's Avatar
needs to be near portland area, I just need to true up my turbo hot side and turbo manny. need to do this tomarrow.
Old Mar 21, 2010 | 11:12 PM
jinxed4dub's Avatar
anyone???
Old Mar 22, 2010 | 12:21 AM
The Spyder's Avatar
Never give up!
You should never take a belt sander to a turbo manifold or any manifold. It will result in a even worse uneven surface. Bare minimum, it should be chucked up in a mill + a fly cutter ran over it. Unless you can find a sander with 220 grit paper (Common metal belt/disc sander uses 24-100 grit paper) I suggest you use a Pineapple crush gasket and call it good. No need for a mill/sander.
Old Mar 22, 2010 | 06:34 PM
jinxed4dub's Avatar
been blowing through those on a weekly basis. I got it milled flat today, and have a stainless gasket to replace carbon one.
Old Mar 22, 2010 | 11:39 PM
XIminipot's Avatar
Yeah using a belt sounder doesn't seem like such a good idea.
Old Mar 23, 2010 | 04:24 AM
jinxed4dub's Avatar
well it passes with a flat edge and a feeler gauge. I'll let you know how it works. Rob at pineapple says thats the way to go.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
Turblown
Sep 30, 2015 05:58 PM
