Warning beeps in a 2ndgen!!
Old Mar 18, 2010 | 06:19 PM
cayusebuster's Avatar
Howdy, my name is brent, I bought an april 1986 rx-7 last spring(love it). Having drove it last summer without problems (except some electrical problems in dash) I threw a fan belt on a trip, trailered it home, and left it sit till spring. I replaced the fan belts, treated her to a new battery, 1/2 gallon of antifreeze, and fired it up yesterday and now I get three beeps constantly while driving without any corresponding dash lights.(they may be out but some have worked in past ) They start in as soon as the key is on, cold or hot and sound continuously. Any help would be appreciated. As far as the electrical problems previous, the temp, volt, and oil pressure gauges never showed a reading, the radio wich worked at first started smoking and quit and the climate controls only work if you hit a bump the right way, however all other controls work and I have seen appropriate warning lights in dash.
Old Mar 20, 2010 | 06:24 PM
farberio's Avatar
NASA-MW ST4
The buzzer is caused by three things:
1. Redline RPM
2. Low Coolant
3. Low Oil, this sometimes turns on when turning right when the oil sloshes to the non sensor side of the pan.
Old Mar 21, 2010 | 01:08 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Warning beeps are covered in the FAQ: https://www.rx7club.com/showthread.p...72#post5131072.
3-beeps, pause, repeat - in case abnormality of stepping motor signal:
The buzzer sounds when there are broken wires or short circuits in power steering pumps coils or the harnesses.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
86glxNA
Sep 15, 2015 04:20 PM
