Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
RX-8 with FD trans?
Old Mar 19, 2010 | 03:36 PM
9000k's Avatar
RX-8 with FD trans?
Hey does anyone know if you can put a fd trans on a rx8 i know that the shifter is set further back on the fd trans than it is on the 8's trans and i think the length is close to the same but not perfect any help would be great.
Old Mar 19, 2010 | 04:20 PM
Japan2LA's Avatar
Why not get the RX8 5speed trans?
Old Mar 19, 2010 | 06:19 PM
9000k's Avatar
well i have a fd trans and there is no 5speed manual trans for rx8. The reason for this swap is i need a stonger trans for FI
Old Mar 19, 2010 | 09:02 PM
t-von's Avatar
Rotor Head Extreme
The transmission will fit the engine. You may have to modify the PPF.
Old Mar 19, 2010 | 09:53 PM
Japan2LA's Avatar
Sorry but you are mistaken..
Rx8 was offered in Japan with 5 speed.. I have actually imported about 10 of them for various people in the last few years...
I will post a pics if you dont believe..
HERE YOU GO....
1st pic is RX8 5 speed trans
2nd pic is RX8 6 speed trans
Bolts right in....Shifter is in the correct place..easy as pie...
Attached Thumbnails RX-8 with FD trans?-rx8-5-speed.jpg   RX-8 with FD trans?-rx8-6-speed.jpg
Old Mar 21, 2010 | 02:32 PM
costas's Avatar
Is it possible for you to measure the distance from the front of the bellhousing (mating surface to engine) to the shifter for the 5 speed box ? any info on the 5 speed ratios?
Thanks
Old Mar 21, 2010 | 09:37 PM
mario1386's Avatar
mazda mario
could u swap the tail housing?they look very similar
Old Mar 21, 2010 | 09:45 PM
Japan2LA's Avatar
Not possible.. but why would you want to?
They are both the same length..
Old Mar 21, 2010 | 09:46 PM
Japan2LA's Avatar
Thanks
They are the same length
Shifter is in the same location on both..
Old Mar 22, 2010 | 12:08 AM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
Rudy?
Old Mar 22, 2010 | 08:19 PM
Japan2LA's Avatar
Anyone interested in getting an RX8 5 speed trans should pm me. I will have 2 in the next container.
Old Mar 22, 2010 | 09:37 PM
diabolical1's Avatar
this 5-speed that you mention, is it based on the old Turbo cases? if not, why would someone want to replace the 6-speed? just curious ....
Old Mar 23, 2010 | 12:19 AM
t-von's Avatar
Rotor Head Extreme
My guess is the 5 speed gears are wider so it may hold more power.
Old Mar 25, 2010 | 06:28 PM
Japan2LA's Avatar
The center section is same as FD3S not FC3S
The 6speed is super weak.. They Break all the time..
The 5 speed is actually a stronger trans
Thats why..
Old Mar 25, 2010 | 10:36 PM
indeed the 6 speed is weaker. 9000k has my old fd tranny and they are about the same legnth but the shifter is in a slightly different position bolt pattern matches up i think the only the thing that is needed is maybe built up the rear end. after that if the driveshaft is long enough your in business if not the get one that does. that should do it. feel free to correct me if im forgetting anything
Old May 20, 2010 | 08:59 PM
GoRacer's Avatar
Speed Mach Go Go Go
Thats why..
Is it the gears or the synchros that are weak? I was actually thinking of swapping the 6-spd in to my FD.
rxlevi7
Sep 26, 2015 07:28 AM
