Temperature Sender for VDO Gauge
Old Mar 18, 2010 | 04:23 PM
PoorCollegeKidd's Avatar
Combat Ninja
Question Temperature Sender for VDO Gauge
Alright, so after much debate and reading more threads on gauges than I ever imagined, I have decided to grab a pair of VDO vision gauges boost and temp). I went with mechanical Boost and Electric Temp gauges. What I need help on is picking the right temperature sender for the gauge.
egauges.com sends me here: http://egauges.com/vdo_send.asp?Sender=250F_120C_VDO to pick on out, but I have no idea. Any help? Or if you have already installed these gauges (which I know some of you have even bought them from egauges) which sender did you choose? Thanks, just trying to get some of those reliability mods done ASAP!
Old Mar 18, 2010 | 05:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It looks like all of those senders have the same resistance output and temperature range, so the only thing to consider is the hole you're going to thread it into.
Old Mar 18, 2010 | 06:39 PM
farberio's Avatar
NASA-MW ST4
Temperature for what?
Oil temperature should be selected by where the measurement is being taken. See this site: http://fc3spro.com/TECH/MODS/EL/GAUGES/otemp.htm
Here's one for water temp: http://fc3spro.com/TECH/MODS/EL/GAUGES/wtemp.htm
Old Mar 18, 2010 | 06:50 PM
Combat Ninja
Thanks for the inputs!
Sorry, it's for engine water temp gauge to *ahem* supplement the stock one. The sizes for the first group (1/2-14 NPT) are probably the size I'm going to go with and tap and I see that some are for warning lights, or multiple gauges (both of which I'm not going to be utilizing ATM).
The things I am confused about is the spade terminal versus the screw cap, and the floating ground vs the standard ground. How do they change the installation process?
Old Mar 18, 2010 | 10:18 PM
Top Down, Boost Up
Spade terminal vs. screw cap is just how the wire will connect to the sender. Standard ground goes through the body of the sender & floating ground has a 2nd connector for a ground wire. For a car, spade terminal & standard ground will be fine. Just make sure wherever you put the sender it is a grounded location (like the water pump housing).
Old Mar 19, 2010 | 02:59 AM
Combat Ninja
Alright. Thanks. I'll order those tomorrow and see how the install works out for me!
troym55
23
May 25, 2016 12:42 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
