12a to 13bt swap
Old Mar 15, 2010 | 05:09 PM
jball92's Avatar
12a to 13bt swap
For the swap which is easier to do an s4 swap or an s5 swap?
( Rx7_Nut13B ) Either will be ok, S5 more power higher rev limit, S4 easy to swap, less electronics, and manual oil metering pump
S4 Less Problems with electronics manual oil metering pump
S5 More possibility for electronics problems electric oil metering pump
cleann88
Jan 15, 2022 11:28 AM
