Power FC My timing maps any suggestions?
Old Mar 12, 2010 | 01:05 AM
silverfdturbo6port's Avatar
500+hp club
here are some timing maps leading and timing split for my car. suggestions are welcome.
my mods
-1680/850 injectors
-intake port timing is stock ( primary's matched to secondary's)
- exhaust ports are ported
- 38mm wastegate 1bar spring (14.5 psi)
- dudeman AIT sensor
- full 3" exhaust
and more but should no matter lol
Attached Thumbnails My timing maps any suggestions?-timing-leading.png   My timing maps any suggestions?-timing-split.png
Old Mar 12, 2010 | 05:30 PM
arghx's Avatar
rotorhead
I'm not sure I understand the logic behind the split map as I look across the boost areas of the X axis. What octane are you running?
Old Mar 12, 2010 | 08:57 PM
500+hp club
what do you mean? the idea is to learn as i have only tuned megasquirt a little so this is all new to me
Old Mar 14, 2010 | 01:31 PM
arghx's Avatar
rotorhead
How did you go about creating the split map? Why did you pick those numbers? I had a megasquirt, timing is basically the same in principle between the two systems.
Again, what octane fuel are you running? It's very important.
Old Mar 14, 2010 | 05:12 PM
fd_neal's Avatar
the split looks strange to me to. It kinda looks like another leading map... If it was me I would keep the '2' area about that, maybe '4' . For boost areas from 0-8psi I might run 7-9split and 8psi plus I might run around 12split
Leading is something I would think to be OK, maybe slightly agressive.
Old Mar 14, 2010 | 08:52 PM
500+hp club
ok sweet i will try that. any other suggestions?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Microtech
Aug 23, 2015 11:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 19, 2015 01:47 PM
