Catalytic converter question
Old Mar 12, 2010 | 12:00 AM
jrhoffman09's Avatar
makes me sound dumb. but no question is stupid. im kinda new to the rx owner scene. had a 82 gsl for a few years which is what i got now. but i been around em all my life. my gpa had one. and my mom has a twin turbo. but on my 82. on the catalytic converter, im taken it off, but there's something liek a relay or something coming out the side of it. my question is, what is it and is it important? would i be able to just hack saw the thing off because the bolt and nut on it are on it and on it good. i've tried heating it, breaking it, everything but now there stripped. what can i do?
Old Mar 12, 2010 | 12:58 AM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
Picture please? are you talking about the air tube hole?
Old Mar 12, 2010 | 01:49 AM
its 3am right now so imma have to get it tomorrow
and idk if its an air tube. it's jus comin out the side of the converter
Old Mar 12, 2010 | 02:25 AM
Whisper's Avatar
There are no relays on the catalytic converter. They would probably melt. There's an air tube, for injecting air into the converter for emissions, but that's about all I can think of.
Old Mar 12, 2010 | 03:14 AM
theNeanderthol's Avatar
the torquinator
It's the exhaust's overheating temp sensor thingy. All it does is flip on a dummy light on the dash if the exhaust gets too hot. If you cut it off in the wrong place you'll have an exhaust leak. I don't remember what happens when you disconnect it, it might turn on the little light, it might not. I don't recall. Maybe someone else can help us out.
Old Mar 12, 2010 | 03:26 AM
rotornoob's Avatar
emissions r teh sux
i also have an 82 but mine is an s. i thought the exhaust overheat was located inside the cockpit on the passenger side floorboard/hump. there should be no relays running to the cats. the only thing that runs to them is an air line for the air pump.
Old Mar 12, 2010 | 10:10 AM
Kentetsu's Avatar
Yeah, I think the overheat sensor is located on the floor board, not the cat.
And there are no stupid questions, only inquisitive idiots.
Old Mar 12, 2010 | 12:55 PM
Wowanswers came quick! Thank you guys. So I can basically just cut it off and cap it closed?
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
