Sponsored by: CARiD
At a wall Timing marks
Old Mar 11, 2010 | 01:02 AM
rx7cowboy86's Avatar
GhostRex
CA At a wall Timing marks
I got the build on my NA 13b done. that was easy, no problem. I spent the whole day trying to get the damn crank angle sensor set to one of the two timing marks on my front pully. Yes I know about the mark on the crank angle sensor and yes it was set, but damn it this thing just wont time in. I'm going to get the chilton in the morning. Any of you have any tech sheets on how to get this crap done that would be great
Old Mar 18, 2010 | 04:36 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you aligned the the marks on the CAS & the mark on the main pulley, there should be no reason to adjust it again. Make sure the engine is warm and idling under ~1100 RPM, or the ECU will advance timing.
This thread might help you out too: https://www.rx7club.com/2nd-generation-specific-1986-1992-17/cas-timing-742026/.
streetlegal?
Mar 17, 2022 02:46 PM
incubuseva
14
Sep 3, 2015 12:37 PM
