90 gtu rough idle seems like a misfire, popping noise please help
Old Mar 10, 2010 | 02:44 PM
dkaszak88's Avatar
NJ 90 gtu rough idle seems like a misfire, popping noise please help
so i just bout this 90 gtu with a few problems. the only one im a little nervous about is that it idles a little rough and im hearing popping noises coming from the exhaust. the idle bounces from about 1000-1300 rpms when it warms up that to me seems like iacv or something but im not sure im just hopping i dont need to replace apex seals or anything right now, and also wen i put it in gear the engine sound becomes much deeper even if im not revving or drivin. any help please!!
Old Mar 10, 2010 | 03:57 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Test the TPS: http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1. Look for dead spots in the range, or if it's out of spec. You can also look for sources of air/vacuum leaks that will make the idle bounce around.
Aaron Cake's Avatar
Engine, Not Motor
Adjust the TPS per factory specs.
Check for any vacuum leaks.
Clean the BAC valve and test its operation as per the FSM.
Change the plugs and wires.
Old Mar 10, 2010 | 03:58 PM
Aaron Cake's Avatar
Engine, Not Motor
Sweet. Simultaneous post.
Old Mar 10, 2010 | 04:01 PM
Top Down, Boost Up
The universe is going to implode now .
Old Mar 10, 2010 | 09:13 PM
dkaszak88's Avatar
thanks good info u 2 help me out alot, ive been messin around i think the popping is an exhaust leak, but it seems to go away sometimes so im not sure. but ill keep messin with it.
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
83revival
Sep 3, 2015 10:42 PM
