Rx7 start-up problems
Old Mar 8, 2010 | 06:30 PM
Lepprykaun's Avatar
No Rotor No Motor =)
Unhappy Rx7 start-up problems
Hey everybody i recently tried starting my rx7 up after keeping her hidden away in my garage throughout winter (stock 93 fd3s rhd). ( i started her almost everyday) This was the first time she sputtered and wouldn't start. Normally i've never had problems on start-up until now. After a few turn-overs i looked underneath and noticed a pool of gas Anyone have a similar problem like this or might have an idea as to what it is? I haven't had time to get under her and start tinkering due to my schedule but maybe a cracked fuel line? My engine doesn't seem to be getting gas so i think that may be it but any advice would be appreciated!
Old Mar 9, 2010 | 02:37 AM
datz's Avatar
GNARKILL
i'm no expert but without the fuel pump running a "cracked" line would only loose the pressure in it wich is not much gas, maybe a shotglass or less.
Old Mar 9, 2010 | 09:43 AM
gracer7-rx7's Avatar
needs more track time
Start with the de-flooding procedure
http://www.rx7.com/tech/unflood-fc.html
http://www.rotorwiki.com/index.php/Unflooding
Shine some light under the engine bay and try and see where the leak might be dripping down from the block.
Also read this thread:
https://www.rx7club.com/forum/showth...hreadid=113638
Could be fuel line, massive flooding, Fuel Pulsation Dampener or other leak.
There is also a procedure to test for fuel leaks but I can't seem to find it right now. You are welcome to do a search in the 3rd gen section to find that thread.
Old Mar 14, 2010 | 11:40 PM
Lepprykaun's Avatar
thanks for the info! appreciated
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
Sharkbait24
Aug 12, 2015 10:36 AM
