90 fc exhaust
Old Mar 6, 2010 | 08:39 AM
dkaszak88's Avatar
NJ 90 fc exhaust
got a 90 gtu, and i plan on doin a full exhaust, but im curious will it lose low end from having less backpressure and how much can i expext to gain from a full exhaust eliminating precats and using high flow cat. im new to peformance with a rotary i was a honda guy for a while, any info please!!
Old Mar 6, 2010 | 10:55 AM
Aaron Cake's Avatar
Engine, Not Motor
With your 90 GTU, you are free to run any kind of exhaust you wish as long as you keep the airpump. This means a good header, high flow cat, and whatever cat-back you will enjoy.
Only S4s rely on exhaust pressure to operate the aux ports, you S5 uses the air pump. So the car will make the most power when all exhaust restriction (backpressure) is removed.
Old Mar 6, 2010 | 03:37 PM
dkaszak88's Avatar
yea i was looking into doing the rb header high flow cat and then cat back. what kinda power gains can i expect?
Old Mar 7, 2010 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
About 15HP.
Old Mar 8, 2010 | 08:26 PM
dkaszak88's Avatar
wow that much? will i be better off geting the straight pipe with no cat?
Old Mar 8, 2010 | 10:45 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Slight power difference between straight pipe, presilencers and high flow cats. Whether anyone has dyno'd all 3 on the same car is doubtful, but it's not going to be huge. The biggest difference will be noise. A header + straight pipe is deafening, a cat will do the most noise control, and a presilencer will be the middle ground.
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
