Where do I add manual transmission fiuld?
Old Mar 6, 2010 | 06:20 AM
Skaterking's Avatar
I like them top down
I thought you added fliud at the top where the shifter is. But an FSM shows a plug is where you add fliud at. But it only shows a Turbo transmission and I don't see some of the plugs that they show. Can anyone help me out? And the plugs the same on a manual transmission. Am I incorrect in wanting to add fliud where the shifter is?
Old Mar 6, 2010 | 10:56 AM
Aaron Cake's Avatar
Engine, Not Motor
The NA transmission has a drain plug on the bottom, and a fill plug on the drivers side, roughly in the middle of the case.
You do not add oil by dumping it in the shifter housing as the shifter housing is remote and it will take FOREVER for oil to flow (weeks...).
http://www.aaroncake.net/rx-7/transfluid.htm
Old Mar 10, 2010 | 10:17 AM
LikeThunda's Avatar
Lol
^^^ wow weeeks? that sucks lol.... ive never done that before ..but i hear alot of people say to fill transmission through the shifter housing... but yeah fill plug on drivers side works..but is hard to get to.... i used a tube connected to a little pump..worked just fine.
Old Mar 10, 2010 | 11:12 AM
dgeesaman's Avatar
The shifter housing has an oil seal blocking flow to the rest of the transmission. If the oil seal is torn up it might eventually fill up. If it's in good condition it will take forever.
Dave
Old Mar 10, 2010 | 12:20 PM
drift my fc's Avatar
go buy youself a hand fluid pump from a autoparts store and start pumping a good workout for your shoulder........look for a plug with the square head sticking out on the driver side near behind the starter usally is the in the front section of the gear case using a adjustable wrench
Old Mar 10, 2010 | 01:30 PM
mazdarotaryfan's Avatar
some transmissions you can fill from the shifter housing, just not these cars.
Old Mar 10, 2010 | 03:43 PM
gracer7-rx7's Avatar
needs more track time
Word to wise. Always loosen the fill plug before draining. Sometimes the fill plug is on so tight that it can't be loosened. If you drain first, you are seriously screwed.
Old Mar 10, 2010 | 03:47 PM
TICALx9's Avatar
^^ words of wisdom my friend. This little tip has saved me from a huge headache quite a few times...
Old Mar 10, 2010 | 03:57 PM
Aaron Cake's Avatar
Engine, Not Motor
A seized fill plug happened to me once. I used the little trick on my website to fill the transmission from the drain plug (sealed up the plug with some putty while the hose was in place) then quickly pulled out the hose and screwed in the drain plug. Good thing the transmission case air vent was working...
Old Mar 11, 2010 | 02:59 AM
Oliver L. Winter's Avatar
hi aaron i just took a look at your site, quite alot of info in there. I will if you don't mind i would like to forward your site on for people who have problems with cars and your friends have good sites too.
Old May 10, 2010 | 02:50 PM
Skaterking's Avatar
Thanks for the advice guys. I bought me a kick as pump worked well.
Old May 10, 2010 | 04:38 PM
rxtasy3's Avatar
pre 81 trannys can be filled that way.
Old May 10, 2010 | 05:56 PM
datz's Avatar
GNARKILL
o ya its a good workout!
Enzo1944
Sep 6, 2015 08:57 AM
