Dash Lights
Old Mar 6, 2010 | 12:36 AM
RO74RY's Avatar
Dash Lights
Hey guys
awhile ago my dash illumination lights stop working, now ive finally got round to removing all the dash and every thing installed new bulb to find that they still dont work. has anyone had this problem my car is 1983 series 2 rx7
cheers
Old Mar 9, 2010 | 12:13 PM
LikeThunda's Avatar
Lol
have you tried checking the Fuse? most likely Your 15A Fuse Blew out... no need to go and replace Bulbs
Old Mar 9, 2010 | 02:18 PM
Kentetsu's Avatar
Look under the shifter cover, and you will find two wires that look like they should be connected, but actually shouldn't. These are for use with auto trannies, and if you connect them then you will prompty burn up the dimmer dial.
There are three connections at the back of the dimmer dial, and if you connect two of them together you will get your lights back, but only at full brightness. But it is a good way to get by until you can find a replacement.
Old Mar 11, 2010 | 12:50 PM
KidA's Avatar
TBROC
it's probably the wires
Old Mar 12, 2010 | 03:48 PM
RO74RY's Avatar
Talking
PROBLEM FIXED
Thanks for all the help guys it ended up being the dimmer switch
Cheers
The1Sun
Sep 7, 2015 10:21 PM
