need ideas
Old Mar 4, 2010 | 10:21 PM
JG797's Avatar
RXCRAZY
need ideas
I bought a 88 RX-7 convertible noin-turbo that was sitting for 5 yrs. I dropped and cleaned the tank, replaced fuel pump,fuel filter, starter, ECU, plugs, wires, and fuel injectors. I have good rotation, good compression, and good spark but it will not start. Any ideas on what the problem might be would be helpful.
Old Mar 5, 2010 | 04:21 PM
hioctane-dtc's Avatar
What is the mileage on the engine?
It may have been flooded and left sitting there for a long time.
Old Mar 5, 2010 | 04:36 PM
rxtasy3's Avatar
since u opened up the fuel system maybe there's still air in it.
Old Mar 6, 2010 | 10:55 AM
JG797's Avatar
RXCRAZY
need ideas
It has less than 75,000 miles. I am getting fuel to the injectors and through the injectors. Thanks for the ideas but I had finally had enough and I had the Mazda dealership come and pick it up.
Old Mar 6, 2010 | 12:40 PM
Go48's Avatar
Verify that you have spark and fuel, and then check compression. How did you verify that the injectors were flowing fuel?
Old Mar 7, 2010 | 10:43 AM
JG797's Avatar
RXCRAZY
Once I put the intake ans throttle body back together after putting new injectors in I turned the key I pulled the the leading plugs and the were wet with oil and fuel.
Old Mar 7, 2010 | 01:52 PM
datz's Avatar
GNARKILL
its flooded for sure.
the spark plugs should smell like gas a little but never be wet with fuel.
Old Mar 7, 2010 | 02:17 PM
rxtasy3's Avatar
^dude that's what flooded is. the plugs may still spark a little but ignition wont happen.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
dexter snoek
Sep 29, 2015 09:18 AM
GKW
Sep 28, 2015 04:34 PM
