rx7 fc swap
Old Mar 2, 2010 | 09:37 PM
manuels 1st gen's Avatar
jackels fd
rx7 fc swap
hello i have a 87 rx7 that im looking to do a 89-91 (s5) swap but i wanna know what i need to get first i have the motor,tranny,harness and ecu.....do i need a new drive shaft,sensors,coilpack or injectors thanks for your time
Old Mar 3, 2010 | 01:14 PM
Pele's Avatar
Right near Malloy
You had another thread that said that you were doing a Turbo swap into a N/A car.
Firstly, the S5 ECU will not plug into the S4's interior wiring harness. There will be some custom wiring that needs to be done.
Secondly, you will need a custom driveshaft made up to work with the small N/A rear end unless you swap out the rear differential to a turbo unit as well.
Azevedo
26
Mar 1, 2019 09:19 PM
