OK started working on her
Old Mar 1, 2010 | 06:54 AM
catzklawz's Avatar
NV OK started working on her
OK,
I am working on a 1989 FC S5, GLX
it is not running yet
I have been through the ignition system, I hooked a timing light to all my coil outputs and I get a reading at all 4. kind of a hokey test but it worked
I have replaced the air fiilter and all 4 plugs are new.
Now I am onto the fuel system, I thought I smelled gas at the intake, might just be engine smells after re-evauluating last night....but.....it doesn't seem like the fuel pump is working. How loud should it actually be listening at the fuel door or the access port in the floor.....can I test it by hooking it up directly to 12v, that way I can check the relay and the pump. or am I starting at the wrong end
Thanks in advance
Old Mar 1, 2010 | 08:42 AM
Pele's Avatar
Right near Malloy
Definitely the wrong end.
There's a two pin yellow/green connector near the air filter box that triggers the fuel pump. Plug a jumper wire into those two pins and the fuel pump should run when the key is on.
Old Mar 1, 2010 | 12:15 PM
LikeThunda's Avatar
Lol
yeee like ^^^ said.
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Aug 14, 2015 04:18 PM
