86 driver door stuck!
Old Feb 27, 2010 | 09:31 PM
ROB&FC's Avatar
s4 GENERAL
Unhappy 86 driver door stuck!
hello
i just closed my door went for a run and came back parked in my spot and tried to open the door and FAIL it wont open. I took the door panel of just now and tried pulling on diff things and still no open . its unlocked but wont open. so i had to exit my car threw the window D1, lol its too dark to see in the door so ill try again tomorow. it wont open from the outside or inside... and i noticed that my outside door handle is way loose the whole **** is out a 1/4 inch..?
anyone have or had this problem b4?
thx rxclub!
Old Feb 28, 2010 | 09:56 AM
Aaron Cake's Avatar
Engine, Not Motor
A small spring on the latch has probably failed. You need to remove the interior door panel and unlock the latch from inside the door. I don't recall exactly what you have to press but it should be fairly obvious when you get in there.
Apoc3D
Sep 5, 2015 10:24 AM
