power problem.
Old Feb 25, 2010 | 04:16 PM
Murrayyy's Avatar
Guess she doesnt wanna go
power problem.
i have an 86 base model with emission removed. i just got it and its already giving me major problems. in 1st gear it bogs really hard when trying to accelerate. at any time. can anyone tell me what this is? or be of an help at all
Old Feb 25, 2010 | 05:03 PM
RotaryRocket88's Avatar
Top Down, Boost Up
In your intro post, you said the car has a 3" straight though exhaust. Besides being oversized for the car (2.5" is more than enough), an open exhaust on an S4 will render the auxiliary port actuators useless. The previous owner probably wired them open to get around this. The result is a big loss of torque under 3800 RPM.
You may also have problems with the emissions removal that when combined with wired open ports leads to poor driveability. It's difficult to say what exactly, but vacuum leaks are common, and a lot of people botch the removal process. You might want to find some of the many removal threads in the 2nd gen section, download the FSM, and get to work checking over everything that's been done to the car.
Old Feb 25, 2010 | 05:39 PM
Murrayyy's Avatar
thanks man. i should also add it floods everytime i shut it off and im told theres a stuck open injector( possibly) but i have 4 stock ones i can fix this with if need be
Old Feb 25, 2010 | 05:51 PM
Top Down, Boost Up
Take a look at this thread for hot start info: https://www.rx7club.com/new-member-rx-7-technical-256/starting-problems-become-more-tricky-889110/. The link in there explains how to modify the injector duty cycle on hot starts. This will not work if the injectors are actually dirty enough to leak fuel.
Old Feb 25, 2010 | 06:00 PM
Murrayyy's Avatar
so can i just remove the cold and hot start altogether?
Old Feb 26, 2010 | 11:56 PM
datz's Avatar
GNARKILL
AZ
ya you can but its the stock ECU that does that for a good reason
Old Feb 27, 2010 | 12:14 AM
Murrayyy's Avatar
i want it too just stop flooding and run right so i can get to a job if i get one soon and save for a cosmo. i found a place that imports eunos for around 7500 so ya
rgordon1979
40
Mar 15, 2022 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
