help found my issue and its not tps!
Old Feb 22, 2010 | 12:10 PM
joshrx788's Avatar
AR help found my issue and its not tps!
ok so i got mad after buying a brand new tps and 2 use ones and my car still having the same issue with the car so i made the test tamp thing and found that i get 3 flashing light on the DCC1 plug so i looked that up and it come to Water thermo sensor. is there any way to check this to see if the Water thermo sensor is good ? any help would be great.
Old Feb 22, 2010 | 12:19 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The FSM Fuel and Emissions section should have a resistance or voltage value you can test for either at the sensor, or at the ECU.
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
incubuseva
14
Sep 3, 2015 12:37 PM
86rxNa
Aug 11, 2015 11:51 AM
