Full manual brakes! Ideas?
Old Feb 21, 2010 | 04:03 PM
gawdodirt's Avatar
Been here since dirt...
AZ Full manual brakes! Ideas?
Going to go to full manual brakes because of running a PP for a track only car. Any thoughts on what stock master cylinder to use WITHOUT a booster? I plan on using a 7/8" and leave the booster , or make a standoff to get rid of it entirely.
I've used Willwood duals with balance bar and was less than thrilled. Better luck with a tandem cylinder and using a manual proportioning valve.
I'm asking what model has a 7/8" master that will bolt up, and any ideas or other options. You guys have got way more parts experience than I do.
Thanks!
GD
Old Feb 21, 2010 | 04:36 PM
jgrewe's Avatar
GET OFF MY LAWN
My dual master set up has a 5/8 and 7/10, and I had to change the pedal ratio to get into that range. A 7/8 may be a little too big with the stock pedal ratio.
Old Feb 22, 2010 | 01:27 PM
gawdodirt's Avatar
AZ
Thanks for the info! So it looks like a 3/4" might be more in line. I'm not sure what a "7/10" is. Maybe a .750"?
I do have a full set up for 3/4"CNC master and a Kelsey Hayes prop valve.
Do not like the balance bar system. Very bad for mechanical losses to the cylinder. I'd rather use a tandem and prop valve.
Thanks again!
GD
Old Feb 22, 2010 | 02:03 PM
j9fd3s's Avatar
Community Builder
i've been driving my P port around without the booster hooked up, and its surprisingly ok. it feels like a gsl-se, but with a firmer pedal.
is it ideal? no. am i going to hook up the booster? yes. is it drivable in the meantime? yes
car in question is an 82 with GSL brakes
Old Feb 22, 2010 | 02:52 PM
jgrewe's Avatar
GET OFF MY LAWN
7/10 is a .700 dia, just a little under a 3/4. That was the step that Tilton had to work with the 5/8 for the front.
Old Feb 22, 2010 | 03:50 PM
gawdodirt's Avatar
Thanks for the clarificaiton. I honestly would not have vacuum brakes on a "TRACK ONLY "car. This is a very large PP of the MFR variety.
It should be WOT most of the time or I need to increase my driving skills.
Thanks,
GD
Frisky Arab
13
Aug 18, 2015 05:30 PM
Turblown
Aug 14, 2015 04:48 PM
