Microtech BAC Question
Old Feb 20, 2010 | 07:40 PM
MaczPayne's Avatar
Mac Attack
BAC Question
Is there a way to tell if your LT8s unit has the PWM option for the BAC installed?
Old Feb 22, 2010 | 04:32 AM
bumpstart's Avatar
talking head
screen 29 aux output screen has the auxAIRmin and max, auxRPMset ETC functions enabled
Old Sep 4, 2010 | 10:30 PM
MaczPayne's Avatar
Mac Attack
How do I tune the auxairmin and auxairmax values? I have the white wire connected to the ground on the BAC, and a 12V ign to the power side. The solenoid opens when I apply direct ground.
I can't affect the BAC valve no matter what values I give to auxairmin, auxairmax, and auxRPMset. Don't know what the problem is.
Can I still attach the blue/red "aux input" wire to the 12V signal off the a/c compressor in addition to using the MT's PWM to control idle?
My problem is similar to this gentleman's: http://performanceforums.com/forums/...php?t=67222496
Old Sep 5, 2010 | 03:18 PM
MaczPayne's Avatar
Mac Attack
Ok, so I have connected the blue/red input wire to the compressor wire to get 12V whenever I use the a/c.
Adjusting the InpAIRadd values did nothing to increase idle, the BAC has 12V switched as well as the white aux output wire connected. Any ideas?
Old Sep 9, 2010 | 02:07 AM
rx72c's Avatar
Top Answer: 1
lt8s wont have it.
Old Sep 9, 2010 | 08:07 PM
MaczPayne's Avatar
Mac Attack
Damn, why would the computer have those functions then? That's so bogus.
Thanks again, I really appreciate the help!
Old Sep 11, 2010 | 01:28 PM
RotaryEvolution's Avatar
Sharp Claws
it's a generic tuning program that has options for virtually all microtech units but doesn't support them all.
Old Sep 13, 2010 | 03:34 AM
Barbantus's Avatar
Eradicator
Does anybody have information on how to run the factory ECU as a piggyback to control the IACV and OMP? I'm using an LT8S as well. I just ran a new Microtech harness and found out somethings can't be connected.
Old Sep 13, 2010 | 09:41 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't think you'll be able to do that. You'd need to get the VR signal to the factory ECU and the Microtech, which probably won't happen unless you mount another set of VR sensors. And the factory ECU would need another complete set of temperature sensors and TPS.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
