Will my potential setup have a bad Bias??
Old Feb 18, 2010 | 08:59 PM
RXILVER7's Avatar
Grabbin My Wankel
I was looking on racingbrake.com and thought of a brake setup I might do on my FD, but I wanted to know if anyone has tried this and if so what is the braking bias.
I was thinking of rebuilding all my stock calipers and buying the two piece front rotors from racing brake. I also wanted to buy the rear big brake kit which uses stock calipers and a larger two piece rotor. I would use Hawk HT-10 pads all around.
Any thoughts/suggestions would be welcome.
Thanks in advance
Old Feb 19, 2010 | 12:50 PM
gracer7-rx7's Avatar
needs more track time
No point in buying a big REAR brake kit unless you do a big FRONT brake kit.
Yes you will have bias issues if you only do the rears.
What issues are you having with your current setup that makes you want to make changes?
Old Feb 19, 2010 | 03:17 PM
RXILVER7's Avatar
Grabbin My Wankel
My current brake setup is non existent. I have stock calipers and drilled and slotted oem replacement brembo rotors and hawk pads with steel braided brake lines. The calipers are leaking and desperatley need a rebuild, the rotors have developed cracks around the drilled holes (i'll probably never buy drilled rotors again) and that hawk pads need to be replaces anyway. The steel lines are doing just fine .
My old setup at full function worked fine for the street, but I want to start tracking my car and I'm looking to beef up the braking ability. I've been doing some research and talked to the people at racing brake (they were very helpful by the way) and they said using stock calipers with two piece front rotors, upgraded pads, and one piece rear rotors I would have a track worthy brake system.
Any thoughts?
Old Feb 19, 2010 | 03:45 PM
Mahjik's Avatar
Mr. Links
For the most part, they are correct provided you have the right brake pads. There are instances where you may still need more cooling for your braking system (depending on the track and your driving level).
Old Feb 19, 2010 | 06:01 PM
RXILVER7's Avatar
Grabbin My Wankel
Well my driving level = low
and I would be on the tracks close to here, those are lime rock and englishtown.
Old Feb 19, 2010 | 07:11 PM
YOu don't need big brakes for either of those tracks at your skill level. The speeds are pretty low there. I'd follow RB's recommendation of their rotors and get some ET800 pads. The ET800s are actually quite good for a combo street and track days until you get more experienced (and faster).
Old Feb 19, 2010 | 08:29 PM
RXILVER7's Avatar
Grabbin My Wankel
Sounds good to me.
Thanks guys
Old Feb 20, 2010 | 03:03 PM
Here is a front only option:
http://pettitracing.com/rx7/index_brakes.htm
There is also Stoptech for near the same price for the front only.
rx7jocke
72
Jun 17, 2016 03:48 AM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
The1Sun
Sep 15, 2015 04:45 PM
windom
Sep 11, 2015 04:48 AM
