[Hello] I'm here for Rx7 tuning and help.
Old Feb 17, 2010 | 06:07 PM
TheRx7's Avatar
My name's Michael, Im purchasing an 87 FC N/A and I would like some advice before/after purchase for what to look for when I go to see the car. Apparently the guy says it runs a bit rough and is kind of hard to start,( does that mean timing is off?) and it has a rebuilt engine that has 26k miles on it. Any Advice anyone?
Thanks :O
Old Feb 18, 2010 | 11:55 AM
RotaryRocket88's Avatar
Top Down, Boost Up
A rough idle can be due to incorrect mixture or vacuum leaks. And hard starting (mostly when warm) can be due to dirty fuel injectors, the rich stock start map or low compression.
Old Feb 19, 2010 | 01:48 PM
TheRx7's Avatar
if it has low compression, does that mean the apex seals are leaking?
Old Feb 19, 2010 | 02:09 PM
Top Down, Boost Up
Low (or no) compression can be caused by damaged, worn or missing apex seals or side seals. It's a good thing to test for when buying a car, but if the engine really does only have 26k miles, it's not that likely. A lack of power will be the most obvious sign of a blown engine, while an engine that's just not quite making as much compression as it used to will be harder to notice.
http://www.rotaryresurrection.com/2n...ion_check.html
Old Feb 19, 2010 | 02:22 PM
TheRx7's Avatar
ahh Fa sho dude t hanks for that. I knew everything else but removing the EGI fuse. Haha. Thanks, I'll try it out when I get home.
Azevedo
26
Mar 1, 2019 09:19 PM
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
