Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek WAY bigger injectors
Old Feb 15, 2010 | 03:30 PM
abtosway's Avatar
Two doritos, on a stick..
Hi, I have an s5 motor in my 79 rx7. I have a t67 turbo and 1600cc secondaries and 720cc primaries. Can an rtek 2 and a safc neo on top handle these injectors?
Thank you
Old Feb 15, 2010 | 06:22 PM
solareon's Avatar
It may work but the transition will suck and it may hesitate rolling into boost. I'd recommend looking at a different injector setup
Old Feb 16, 2010 | 04:01 AM
abtosway's Avatar
would it be better if I used a 720, 1300 combination?
Old Feb 16, 2010 | 12:18 PM
BFGRX7's Avatar
Well, DAMN!
You might want to check out my thread....
https://www.rx7club.com/rtek-forum-168/2-1-fjo-injector-driver-950-1000%3Dwin-871863/
I went with 950/1000 for my set-up and it has worked well (albeit with a few adjustments). While i've gone with injectors I had sitting around, you could essentially add larger secondary injectors due to your ability to add larger primaries.
~M
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
connerfd3s
Sep 19, 2015 05:58 PM
