Sponsored by: CARiD
best short circuit tester?
Old Feb 15, 2010 | 02:41 PM
walken's Avatar
Registered Loser
preferably one that is idiot proof. something I can throw in the fuse spot and run a wand over the crusty old wiring harness.
I know with a multimeter I could test everything individually, but i'm lacking time now days.
Old Feb 18, 2010 | 12:25 PM
farberio's Avatar
NASA-MW ST4
Interestingly, a multimeter will do just that. Throw one end on the fuse area and probe with the other end. Set the multimeter for continuity (i think) testing and it should beep when the wires are probes are connected.
Old Feb 23, 2010 | 09:05 AM
TheRotaryGF's Avatar
^ Agree with farberio. The continuity tester on the multimeter will do just that. You will just need to place one probe in the fuse area and run the other to the end of cable that you are testing and that will tell you whether or not you have a short in the wire. I do not know of any other tool that can actually test for a short through the jacket as your suggesting with the wand though. I do have one that can do it with 110+ V, mainly for AC power, but the low voltage that runs through the car may be too low for something like that to work. Not sure.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Sethix
Nov 3, 2017 11:48 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
