Canadian Forum Canadian users, post event and club info here.
Power bleeding for brakes who?
Old Feb 15, 2010 | 01:56 PM
Bwek's Avatar
High Comp Booster
hey guys is there anyone that happens to have a power brake bleeding machine?
I got my brakes bled but it seems like there is still air in it and i can't seem to get it driving me nuts
I've got a kit to bleed them and it isn't my first time lol
Old Feb 15, 2010 | 07:19 PM
dradon03's Avatar
Derwin
I powerbleed on all my cars works amazing and uses little fluid gets everything out in one shot. It is one of those things that you dont believe how good it works until you try it
Old Feb 15, 2010 | 08:42 PM
Bwek's Avatar
High Comp Booster
ya i know i'd love to get it done to my car i dont like how it has abit of squish lol esp after putting new pads and calipers on i want the most i can get out of it
Old Feb 15, 2010 | 09:51 PM
dradon03's Avatar
Derwin
Powerbleeding will give you the best pedal feel right away.
Also, you will do the entire system in about 10 minutes.
Old Feb 16, 2010 | 10:07 AM
londonmazda's Avatar
the canadian tire i used to work at had one, maybe ask an older mechanic to bleed your brakes at CT.
Old Feb 16, 2010 | 03:48 PM
classicauto's Avatar
Crash Auto?Fix Auto.
You may want to take into account that if the master cyl. is aged, the pedal will not feel 100% correct.
Also, old flex lines can cause a bit of squishy-ness. Pads and calipers do not a complete brake system make (since we're jumblin' scentences)
Old Feb 16, 2010 | 05:05 PM
Bwek's Avatar
High Comp Booster
I have new front and rear calipers and a new master cylinder as well actually the passenger rear wasn't replaced yet
Old Feb 18, 2010 | 10:01 PM
DynoDragon's Avatar
Rotorite
You should be able to achieve good results with a manual kit, if all the components are good. Sometimes you just have to bleed a little more fluid. Make sure the hose from the caliper is going up and is full of fluid before you close the valve, otherwise air can be sucked back in.
If the pedal is still not firm, as Joe said, it's time to check through the system components. Braided steel lines help; are you getting flex at the firewall, etc.
Old Feb 18, 2010 | 11:34 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
FC's have a crappy feeling brake pedal. I've seriously never sat in one that felt great. I think it has to do with the ABS, but I've sat in non-ABS cars that are crappy too.
I've got a mazda 626 brake cylinder that's a direct upgrade (larger bore) and is brand new, if you're interested and want to bother.
Old Feb 18, 2010 | 11:54 PM
Bwek's Avatar
High Comp Booster
I hate you Dan why do you have all these awesome parts, im just going to give you my paychecks from here on out
Old Feb 19, 2010 | 07:00 AM
Redshft's Avatar
Spinning Dorito
The pedal feel in my FC was greatly improved by putting a brace from the strut tower to the front of the master cylinder. The flex in the firewall is really surprising. (Watch the master/firewall while somebody else pushes the pedal. You will be shocked.)
That being said, I've been toying with the idea of picking some kind of bleeding tool.. between all of the cars, and the frequent changes on the race car, the old-fashioned method has lost it's novelty. Time for more power tools.
Old Feb 19, 2010 | 08:17 AM
Buggy's Avatar
I've Been Wankeled!
We have a nice setup here at work, came from Snap-on. It's a pressurized container that you fill with brake fluid and then pressurize with compressed air. It gets hooked up to the master cylinder and pressurizes the whole system. Just walk around to all 4 corners and crack the bleeder screws. Takes about 5 minutes to bleed a completely dry system. Also great for flushing a system out. Not sure what it costs though.....
im_the_mainevent's Avatar
Cambridge Tire
Maybe a dumb question but when you put the new master in did ya bench bleed the thing? 90% of problems after a master replacement are from improper bench bleeding.....
Just a thought here....
Old Feb 19, 2010 | 03:14 PM
Bwek's Avatar
High Comp Booster
Ya i bench bled it
its def not lines, air the pedal moves to a certain point then its really firm like it should be.. if you get what i mean theres a slight amount of play the brakes do engage but its not firm right at the beginning of travel like it should be
Old Feb 19, 2010 | 03:29 PM
Buggy's Avatar
I've Been Wankeled!
Just check to make sure all the pads can move freely, especially the rears. Make sure all the slides are serviced and lubricated as well. A stuck pad or caliper slide will give you the same kind of pedal feel. Like a rear drum brake that isn't adjusted right.
alphawolff
Nov 17, 2015 05:57 PM
travenport
Aug 29, 2015 11:15 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
